Miles said:It looks to be the cubic root of the pole count ratio?
Miles said:Just had a simulation session with the new feature.
Interesting result..... Nothing to be gained by decreasing the magnet radius relative to the airagap radius, in fact the best result was obtained by using a plain rectangular form (flat top)!
Well, as it happens, I do.John in CR said:Have you put any effort toward designing the bike you want to put it on? You must have some ideas already for a bike design worthy of your masterpiece of engineering art.
Yes, there's some amazing stuff out there. Axial flux cores are often spiral wound from variable pitch strip.speedmd said:Second, that design had me thinking a slinky style edge wound magnet core outer ring would be perfect. Quick search shows, I am not alone. Some stator cores made that way. Seriously cool.
Are they still being made? I seem to remember a firm in China taking over production?speedmd said:First off, I want a JOBY. No sense in trying to make something that does not come close when I have a complete motor bike to build around something like that gem.
Agreed. I wasn't sure exactly what you meant by "motor bike"speedmd said:The zero stuff looks nice, but way bigger and IMO not suitable for a light weight bicycle build.
Miles said:Are they still being made? I seem to remember a firm in China taking over production?speedmd said:First off, I want a JOBY. No sense in trying to make something that does not come close when I have a complete motor bike to build around something like that gem.
Brian is the one to talk to, here, about Joby: http://www.endless-sphere.com/forums/viewtopic.php?p=670083#p670083
The motor that Ryan designed for Zero is great value for the money:
http://www.zeromotorcycles.com/powertrains/powertrains-sales-sheets.pdf
Different scale to the Joby motors, though.
That would be very interestingtoolman2 said:perhaps i should update the motor comparison thread with some of this stuff, we have all the simulation data for it (and more for the less palatable ca120/collosus) so if we were to do a similar simulation for any of them as you have done here for the 90mm motor, we can then compare those results to the exact real world costs of producing rpm and torque from similar motors.
I'm not sure.zappy said:Would the much superior (in one direction) grain oriented steel be any advantage using this kind of manufacturing method?
Hopefully, I'll get something together this Winter. 30mm loose stator & rotor stacks will cost around $250 in 0,35mm M15 C5, I think. A lot more for Arnon7, I guess. I'm using 10mm long magnets as axial segments so stator lengths could be in multiples of 1cm.zappy said:Any idea of a rough time frame for construction, and basic stator cutting costs?
