So my dolomite is together.
The Achilles heel are the wheels. Well okay and also every single part on the bike....
Seriously though, I have the bike as dialed as it can be, except for the wheels. The hubs, in particular are both poor in design, fabrication, and final assembly.
Ever shoot billiards and roll a pool cue across the table to determine the straightest stick to shoot with? Floppin all around when you roll them?
That's what I am seeing...I would love to see whatever lathe these hubs were turned on. Additionally, the rotor side of the hub is faced improperly - it is not square to the hub body. Finally, I am sure there some whacky stuff going on with the cups/cones regarding how well the bearings travel consistently inside . I can't confirm this, but I remember seeing or hearing that the hub assembly for this quality of bike is press fit with a bottle jack type of press, and the entire assemble is squished together, rather than one component at a time, checking for precision...
I am gonna pull the wheels tomorrow, and try to re - face the hubs, lap the cups with polishing compound, repack with crease, readjust, then touch up the spoke tension.
The hubs wobble on the axle enough due to poor manufacturing tolerances that it exceeds the lateral run out of pad clearance on a properly set up disc caliper. With straight rotors.... Hopefull the wheels will roll smoother, and the rotors will experience less lateral run out. If the latter is not any better, maybe I can find some untrue rotors that mirror the poorly face hubs and get em dead straight!
len
