how about some more ideas.
1. make the mosfets modular. so others can make mini pcb with new mosfets as they come out
2. send power in and out on common metal rails mounted below pcb.
3. input dc pwr and output motor connectors cables directly screwed on metal rails
4. modular mosfets pcbs are screwed on the rails
pwr _________________________________ rails
gnd__________________________________
_____________________________________M0
_____________________________________M1
_____________________________________M2
this way if a mosfet goes u simply unscrew it and put on a replacement. also if better fets come out they can be plugged in. A better arduino comes out just plug it in. you want higher voltage current just plug in the fet for that voltage current.
Arduino blue tooth streams live telemetering data to ur smartphone .
new arduino has bluetooth or wifi or gsm which can provide anti-theft and location alarms.
