EVDragRacer said:
That information sounds great. I must use the 10S packs, already in flight. Can I still use your system with the 10S?
Yes, it can still be done with the 10s packs, it simply requires running a pair of balance tap boards to combine them for each pack, and a little more cramped buss layout.
EVDragRacer said:
Also, if you are willing, I need diagrams drawn up to explain more in detail of what you are recommending. I am willing to pay for support, please contact me at:
ecedraev@gmail.com
My friend, the last thing I would do is try to get a fellow racers money. Racing does a plenty good job taking our money on it's own.
I will absolutely work on pack development for you, and I happen to have a CNC machine and sheets of Poly-Carbonate, and sticks of copper bus-bars.
The only thing I would ask in exchange for helping your project is that you freely and openly share the things learned in your journey, failures and successes, improved procedures and methods, problems experienced with designs etc. The electric drag racing community is so small right now, info needs to come out to show folks methods that work and don't work to help take a big chunk of the development/RnD costs out of grass-roots electric racing efforts. Openly share your project details and work, and you've got my full support.
EVDragRacer said:
I really appreciate your guys help, I have been catching slack from other ev builders stating I cannot balance or install a BMS system on pre-built 10S 5AH packs, they state I must rip apart the packs and make them all parallel. This I do not want to do.
Nope. You absolutely don't need to do anything like that. We've got hundreds of systems, including a number of my own, that have been operating perfectly for years now using the outside discharge leads and paralleled balance taps. You CAN install any BMS you wanted with this method (which you don't want to do), and you absolutely don't have to open any packs.
EVDragRacer said:
I want to state my experience, I have over 25 years building race cars, but with ICE. I am new to the EV world, but learning everyday. Because I am an experienced welder, and mechanic I feel with the right help (instructions) I can build any pack.
Again, thank you all! :lol:
Ron
You sound like my father.
The skills you've got are more valuable to building an EV racecar than having EV specific skills. Likewise, you need to understand that nobody who is an electrician (even the master admin 01 level electrician down the street or that is friends with a buddy) can help you with this project. Likewise, the masters degree having electronics engineer is useless towards helping you do the high-power side of this project. It's unfortunate, but true. Electricians run wires and look up a chart to determine the size, once in a while following a schematic for wiring something. The electronics engineer works in a world of mili-amps rather than kila-amps, and has no concept of inductive path optimization or high current parallel array issues. Don't let these well-meaning folks discourage or steer you off track from the designs we come up with, which will be designed around strong power-electronics principals (the only type of engineer you should listen to if you ever can find one, a power electronics specialized EE, which is sadly extremely rare in the USA.)
