liveforphysics
100 TW
It's all trivial my friend.
Don't even need to spend a thought on it.
liveforphysics said:It's all trivial my friend.
EVDragRacer said:Also, if you are willing, I need diagrams drawn up to explain more in detail of what you are recommending. I am willing to pay for support, please contact me at:
ecedraev@gmail.com
Very very generous 8)liveforphysics said:My friend, the last thing I would do is try to get a fellow racers money. Racing does a plenty good job taking our money on it's own.
I will absolutely work on pack development for you, and I happen to have a CNC machine and sheets of Poly-Carbonate, and sticks of copper bus-bars.
The only thing I would ask in exchange for helping your project is that you freely and openly share the things learned in your journey, failures and successes, improved procedures and methods, problems experienced with designs etc...
Openly share your project details and work, and you've got my full support.
/\ This. I know White Zombie uses a single Zilla 2K with hairball to drive two 9" motors in a similar configuration to yours, so if the controllers can just be run in parallel to bump it up to 4kA, then it should be fine. ..then later add another one to bump it to 6kA...repeat as needed.EVDragRacer said:"The Zilla works excellently with single motor systems, but realizing that many of the quickest EVs use dual motors, the Hairball interface also has a option for safe automatic Series/Parallel shifting of dual motors for even more power and efficiency. "
http://cafeelectric.com/zilla.php?zenAdminID=74843299a81299efa3d61314338bea89&zenAdminID=74843299a81299efa3d61314338bea89&zenAdminID=74843299a81299efa3d61314338bea89&zenAdminID=74843299a81299efa3d61314338bea89
x88x said:/\ This. I know White Zombie uses a single Zilla 2K with hairball to drive two 9" motors in a similar configuration to yours, so if the controllers can just be run in parallel to bump it up to 4kA, then it should be fine. ..then later add another one to bump it to 6kA...repeat as needed.EVDragRacer said:"The Zilla works excellently with single motor systems, but realizing that many of the quickest EVs use dual motors, the Hairball interface also has a option for safe automatic Series/Parallel shifting of dual motors for even more power and efficiency. "
Yes.EVDragRacer said:Not sure if the 1" of 12 AWG will still create a problem?
They're the 5Ah 45/90C Turnigy nano-tech's. So, at a max current level of 4kA they should be putting out 80C, or 400A each. IDK, personally, even for just the short amount of time that this thing is going to be running I wouldn't want to trust 400A to a single 12AWG wire.dogman said:What's the c rate of that pack?
x88x said:They're the 5Ah 45/90C Turnigy nano-tech's. So, at a max current level of 4kA they should be putting out 80C, or 400A each. IDK, personally, even for just the short amount of time that this thing is going to be running I wouldn't want to trust 400A to a single 12AWG wire.dogman said:What's the c rate of that pack?
EVDragRacer said:Okay this is the latest. I have received some of my 10S packs and decided to dissect one pack. The 10S pack is one 5S built over another 5S packs. The tabs are all welded together and the soldering looks good. The problem is the large positive and negative wires are very small 12 AWG, not large enough for the pack size. We must increase wires size for safety reasons. The problem is I do not want to solder near the tab fearing I might heat the pouch cell. I was thinking of cutting the 12 AWG 1" away and then create a solder connection to a large size wire. Not sure if the 1" of 12 AWG will still create a problem? If I can replace the positive and negative wires with larger wires, then my only worry is the balance wires, will they also need to be upgraded? That would be a pain in the azz. I really want to use these Turnigy packs, so I must find a solution. Any suggestions guys?
I purchased the second Zilla 2k today.
Jeremy Harris said:It might be an idea to get the wire gauge thing into perspective here.
10g wire has a resistance of about 0.00075 ohms per ft, or 0.000063 ohms per inch.
If you leave 1" tabs of 10g wire on the cells, then pull 100A though the cells in each pack, these short lengths of wire will lose around 0.63 watts each - is that really a problem?
They won't even get slightly warm at that sort of current, and the volt drop will be just 6.3mV, barely measurable. For comparison, if you run 0000 gauge cables (around 0.00005 ohms per foot) then you'd lose around the same power in about 15 inches of it as you would in one inch of 10g.
Even if you ran at 200A per pack you'd only see a power loss in an inch of 10g of around 2.5 watts, still not enough to get near to heating it up appreciably, let alone fuse it.
Length is just as important as gauge when it comes to wiring high current stuff up, and very short lengths of smaller gauge wire aren't really a problem as long as you keep away from fusing level current densities. To fuse 10g wire takes around 350 amps or so if it's in a reasonable length, far more if it's a very short length attached to a fatter cable that will conduct heat away from it.
Jeremy
EVDragRacer said:Okay, that helps thanks. But, I am still a little confused on how amps and volts will draw from small wires with a small AH pack?
Questions:
* If the pack/wires are used for only 15 seconds (or less) is it possible to keep the pack to a lower ah rate, like 25ah?
EVDragRacer said:* Will it reduce the heat and "stress" on the pack wires if I add more batteries in parallel to up the ah, lets say 50ah or 75ah?
