dekes1 said:Not sure what the problem is with the stock mounting brackets. I'm running 19s (around 72v nominal) at 50-60 amps and although I've broken a chain and tore up a derailleur, I've never bent the bolts as bad as that photo. Those washers actually provide very little surface contact with the mating surfaces and make the whole thing weaker. Use case hardened bolts and the original brackets, make sure the BB nuts are super tight, and this thing will be just fine.
1KW said:so currently no one is offering an affordable ready to buy mounting solution? What about freewheel upgrades ect? Rather build it the first time right, so I dont have to tinker with it 50x.
1KW said:id rather not go gng more chains, more adjustments plenty of problems . Just saying if set up right the first time, i see little that can break this kit from the last hour I've spent reading the reviews. If the mounting system is upgraded, however It seems hardware upgrade, plus a plumbing style rubber brace instead of the zip tie (Lol) would work on anything less than 52v.
gman1971 said:I am unsure why it bent so bad...
And the washers do help, quite a bit actually. I would suggest also adding a block to make the motor sit over the frame tube flush, so it doesn't have a fulcrum point to bend againt...
I would never ride a GNG kit ever again after my last one...
G.
robocam said:Those aren't spacers. They're washers over the long silver threaded tubes to make the setup much stiffer. The idea came from the post in the link below. Unfortunately, with the spacers, the Cyclone just bends other parts, like the bolts instead. The stock brackets for the Cyclone just can't handle the power (at least not at 52V).
https://endless-sphere.com/forums/viewtopic.php?f=28&t=69867&start=50#p1143246
juanfeli said:...Robocam, why you have so many spacers? It is like you are missing the long silver ones....
Really excited to see this one develop.. I'm probably gonna try a BattMan on the build I intended for the CA3. Maybe you want to try the BattMan? It's a lot less complex and cheaper too. Lemme know.gman1971 said:All in all the Trike should be almost operational by next weekend. I am debating about taking the Cycle Analyst off my eBike just to see what its doing, at least during the beginning, but the Cyclone should come with a numeric voltage readout throttle so that would be plenty to get me started.
More updates as they happen.
G.
cmm8622 said:Hey everyone,
Been following this thread for awhile and its been super helpful. Here's my situation: we have a cooperative business that pickups up food scraps and turns them into compost with partner urban farms and backyard gardeners...all by bike. We are getting into the few hundred pound loads, which is fine when its flat, but being the in DC metro area, there are some serious hills that are routes are inevitably going to have to deal with more and more.
A college friend befriended Justin from Grin ("yeah I live with this guy who likes to tinker with eBikes, you should talk..."...small world) and so I asked him his thoughts and he put a few options out and referred me to a fella who electrified the trailer itself, as well as utilized 2 hub motors. The trailer's wheels have strong hubmotors, and this dude is pulling hundreds of pounds on BC Canada hills. Very impressive but I'm not quite there. I'm sold on the mid-drive for now, opting to electrify the trailer down the road.
So first I learned about the BBSHD. The led to reading about the Lightning Rods Small Block kit. I have been on the cusp of ordering a LRSB kit, but that's the holdup...I can't get a response from Mike anymore. That lag in service made me research alternate options because at this point, time is money! The sooner we get a motor setup, the more efficient our operation will be obviously.
So before I place the Cyclone 3kw order, a few questions for you all....and remember, we don't care about top speed. Torque/hauling capacity are more of our concerns.
1) This is moreso for those who have used the LRSB kit....is there any advantage to the LRSB over the Cyclone. In many ways, I'm sold on the Cyclone (I can order RIGHT NOW, its cheaper, and has a good deal of power to get us moving better). But I'd be curious if there's any features to the LRSB that outshines the Cyclone...
2) Is there another kit we should consider besides the BBSHD (well, that's not really a consideration anymore), Cyclone, and LRSB?
3) GMan (and others in this boat): given our situation, would you suggest any tweaks to your drivetrain/gearing setup for increased hauling capability/efficiency?
4) Batteries: when I told the Luna forum I was going to start with a BBSHD and migrate to a LRSB eventually, the 52V 20 Ah PF pack got the most votes. Now I am looking at the Panasonic 52V 24ah GA and Samsung 25r 52V 20ah. Thoughts??? (anyone wanting to suggest Lipo and other battery types, wait for the next question please
5) Batteries pt 2: I have been going at this thinking I would use an 18650, but as a side question, cost aside, is there any reason to consider alternate battery options (Lipo, etc)?
Thanks so much in advance for your help!!
robocam said:After my initial disappointment with the Cyclone's stock bracket, I decided to do something about it, so I added an aluminum bracket and increased the size of the bolts from 5mm to 1/4", and I also used a couple grade 8 bolts along with tight-fitting steel sleeves that increased their diameter to 1/2". I've included a few photos below. The 1/4" bolts fit through the aluminum squares, but they were a tight fit in the black spacers, so I used a tap and threaded them. All the parts were purchased from Lowes.
robocam said:Yeah, I'm definitely going to make some changes to the mount. I still like the Cyclone motor itself. I just wanted to clarify to other readers that the GNG you're talking about is the Gen2 which uses a converted geared hub motor, which is totally different than the belt-driven mid drive that was once so popular, spawning the Lightningrods mid drive. The fault of your original GNG probably lies more with the company that makes the hub motor.
But the current GNG, which is clearly a knockoff of the Lightningrods mid drive, might be worth a try. Based on the components they're using, it looks like they're learning.
G.
gman1971 said:Looking good Robocam!!
G.
robocam said:Thanks Gman! I got a chance to do a test ride today, and it is rock solid! I'm thrilled! I can't wait to try speed 3! Here's a picture of my work in progress.
G.
G.
Aftonrider said:Hello
My kit arrived and I've been mocking up the install on my redundant atomic zombie delta speed wolf. This is my first build so I'm going to check in now and again to ask for your knowledge on the c-3000 kit. I'm starting off with a stock kit with a 4 chain rings. 48-44-36-24. I can upgrade the critical parts this spring, i.e. Chainring freewheel, drive freewheel, wire connectors and such.
1) my trike is 1-1/2" square tube. I'm going to set the motor down low under the main boom to keep the weight low. I can mount the motor as close or far from the crank. Q: if I mount the motor close to the chain rings and have a shorter chain would that be advantageous? I'm thinking yes but please chime in.
2) the motor will be mounted to the square tube in a simple manner with good quality bolts and steel standoffs. I'm just looking for a strong mechinacial fastening. I'll post some pics when I get that far. The motor can be mounted from 90 degrees to 45degrees to the horizontal boom. Q: is there any advantages to mounting it on an angel verses 90degrees to the boom?
3) I'm building this trike on a budget and don't have the $ to buy the Lipo packs that I want so I'm going to get started with some SLA battries. This will get me on the road for testing. 3 12 volt 18Ah will do the trick for the time being and I can get the lipos this summer as the funds become available. I'd like to charge the battries in the trike and not sure what type of configuration I need to wire. Q: what type of harness would I need to charge three SLA battries at the same time.
Any information to help me get my trike rolling under electric power would be awesome. I'm open to suggestions from all of you and thanks so much for the great thread.
Afton Rider
Dom
gman1971 said:Interesting idea of a quad chainrings, you only really need three, but four doesn't hurt, although you might find yourself on the big or small most of the time; and maybe leave the middle for human only?
I'll be doing a square tube install this week as well, so I'll see what I can come up... in the meantime you'll be spearheading the square tube install!
G.
Afton Rider
Dom
gman1971 said:Sweet deal, I might ask you for the drawing of the plate you made! I might "plagiate" your plate idea for the trike!
The bike is going to be awesome in mode#3.
What else do you have left to do?
G.
robocam said:Sure! I'll measure it and make a drawing.
I still have to modify my grips to fit with the half throttle. I like the ones I had, so I'm going to chop off an end so that it will fit. I'm also trying to figure out where to put the turn signal switch that I'm using to control the speed modes. All minor stuff.
G.
