dakh
motomech said:The internals swap between the standard Cutes and the H, but not the CST. Different width stators I believe.
Besides, moving a Cute from frt. to back doesn't change much.
After riding this rig a bit more I'm really jonesing for something a bit lighter and with better balance.
Like when you had a sm. lipo pack at the bottom of the frame?
Can you go back to it and only use the monster battery only when you need the range?
Bummer about CST not swappable, thanks for saving me some $$ trying I could do 16S pack with 201 wind I guess, or 10-12S with the high RPM wind and bump up the amperage, or use 26" rim with skinny tire.
In my mind no reason to use LiPo, if I'm going for a lightweight build I should be using Tesla cells sine they're twice more energy dense. Heck I could just split one of the packs I have, make one 14s2p and one 14s3p 14s2p would handle my current setup that draws 14A max just fine actually. Since I already have loose cells I have room to experiment, and I love me some DIY engineering. Look forward to posts documenting myself trying to fry all this equipment in the future
I will have to feel it to believe it on the front vs. back motor. So far my conclusion is front motor changes bike handling a lot, even with light battery it was already a substantial compromise. Maybe it's because the wheel build I'm using with the powered hub is more burly/heavy than a somewhat fancy/light hub/rim/spokes I compare it to. Instinct tells me I'd like rear wheel drive, battery weight near the crank a lot more. Of course no way to verify that until I ride one. I get substantial (and practical) air time on regular basis on my commute, so say I always use backpack over panniers and no super skinny tires. Having a heavy and not easily manageable weight on the bike makes me slow down for shit I usually fly over, which pisses me off.
