deanhuff
- Joined
- Feb 2, 2021
- Messages
- 1
I have been unable to find answers that I am looking for through any other means, and I see lots of detailed discussion about batteries on this forum so here goes...
I have questions about a processes known as Plug and Ride or "PnR" where a 56V EGO battery is used to connect directly to the charge port of certain older Onewheel + or Onewheel V1 boards. The battery is usually carried in a backpack or mounted to the fender of the Onewheel.
The purpose of this modification is to allow for longer distance riding. To be clear, this is a complete hack, I'm quite sure the manufacturer never intended the onboard battery to be charged or anything to be plugged into the charging port while the Onewheel is moving. It has been determined by removing the 3rd pin of the 3 pin XLR charging connector, the safety mechanism which immobilizes the motor while charging can be defeated. This only works on certain early revisions of the Onewheel+ and V1 Onewheel.
It is reported that a 2.5Ah EGO will yield about 2x distance where a 5.0Ah battery will yield 3x distance over stock. It is advised to plug in a 2.5Ah EGO battery around when the main battery is depleted to 20%, while the 5.0Ah EGO should be plugged in when the onboard battery is between 50-65%. I don't know the reasoning behind this advise.
Other fun facts:
When the onboard battery charges to 100%, the motor cuts out (i.e. you fall...the one onewheel literally has a single wheel and uses gyroscopes to keep you balanced).
Only the + and - terminals are used on the EGO battery, there is no under current protection from the EGO's BMS, so the operator needs to press the button on the EGO occasionally to look for a green/red light make sure it does not drain down below safe levels (42v)
There is another method among Onewheelers known as Vamp and Ride or "VnR" where an ego battery is wired in parallel with the onboard battery. I fully understand the need to match voltages when connecting batteries in parallel. For now, I am staying away from VnR setups because they all require internal modifications to the Onewheel.
The charger for the Onewheel outputs 58.4V at 3.5A so about 208 watts. Voltage falls inline with what an EGO battery can produce, however I have no idea how many amps an EGO can output. The 2.5Ah EGO is 14s1P while the 5.0Ah EGO is 14s2P....I'm guessing these batteries have the potential to output many amps greater than 3.5 from the stock charger.
The Battery on the Onewheel is a LiFePO4 battery, the board states it is 58V 130Wh, by my calculations that's about a 2.25Ah battery onboard.
With all of that explanation out of the way here are my questions:
1. Should I be concerned about initial current flows when hooking the EGO battery into the charger port?
2. Are there any tests I should run or things I should look out for to minimize damage to the onboard battery?
3. Could several EGO batteries be used in succession to maintain even longer rides?
4. Should I wire an in-line fuse between the EGO battery and the charge port to protect the Onewheel? If so, is there a certain product you would recommend for this application?
I have access to a Fluke Multimeter with a 10A / 600V fuse by which means I should be able to measure initial current flows...I have yet to do anything other than order the wiring harness and get some used EGO batteries off Craigslist.
Other fun facts:
