baja ebiker said:
sorry hyena we posted at the same time what is price difference. I'm looking to build a straight up offroad e moto with this thing and go moto seat and pegs. no pedals for now. would like to rip it through the desert for 1-2 hrs. not too concerned about weight as i have no intention of pedaling this thing.
Price depends if you DIY or buy it pre-made. I dont know what delivery is like to Mexico, if there's a local hobbyking and you can make up the pack yourself from RC hobby packs that would be by far the cheapest. You'd be looking at around $1500 in RC packs and a good few hours to assemble it all (I spent the best part of a day rebuild the 16ah battery for my stealth fighter recently and the raptor battery is more than double that size)
Otherwise you could get a pre-made, plug and play 18650 battery made up but it won't be cheap. I'm chasing up some options now for some killer, long range high power batteries but you're talking in ballpark of $2000 for one of that size. So lipo is obviously a fair bit cheaper but it depends on how much you value your time and if you've got the skills to do it. I can't stress enough that you really need to know what you're doing when building lipo packs, particularly huge 40ah ones like the raptor can hold. We're talking about a battery that will happily discharge 1000+ amps if you bump the wires together, 2000+ amps if you're using the better C rate stuff! Alot of us who are more experienced casually talk about building these packs and then noobs come along and assume it's just a matter of twisting a few wires together and wrapping it up in duct tape but it's really not. Unless you know what you're doing with lipo I'm trying to steer people away from it these days. The bang for buck is certainly there but high powered 18650 is just such a better option - safe, neat, easy and no maintenance or balancing required as it's all taken care of by the BMS.
Mammalian04 said:
Thanks Jay. Am I just wasting space by calculating with the interlocking spacers?
Depends on how you will actually construct the pack - if DIYing using those blocks then of course you need to factor that in. If you're having them made professionally and tab welded there's usually minimal spacing between the cells. When I'm measuring out I allow 20mm per cell knowing that it's actually a shade less than that and if I miss out by a few mm on any particular dimension I know it'll still squeeze in.
As an example the new 21S packs I'm using in my conversion kits are a shade over 400mm long, and that includes the BMS too! So under 19mm per cell in a string.
You are also convincing me on dropping from 22s to 20s with all this talk of heat the last few days... I don't need the speed from the extra voltage and with packs this big, it doesn't sound like I will be able to use the extra Amps from the 29E anyway.
Good call, and it's nice to have a bit more tolerance for component ratings too. 29E cells at ~100 amps will sag more than 25R but it's not huge deal in the grand scheme of things. Unless you're really riding hard and constantly hill climbing it'll only be bursting those high currents for a few seconds anyway.
One interesting idea I am playing with though is being able to take half the pack out (22s6p or 20s7p) and run a lighter weight bike when I don't need mega amphours.
Yeah that's doable but you'd probably want a BMS in each pack for maximum plug and play friendliness. You'd also need to make sure both packs are fully charged (or at the same state of charge) when you put them back into parallel as otherwise the higher charger battery will try and dump bulk current into the lesser charged pack.
