livetek what makes the revolt at a kv of 43 so good is you only need a single reduction,= simpler/ lighter .....livetek said:Oh sorry, i wasn't thinking the Revolts motor are Outrunners, that's great ! But i can't find picture of the motor mount..
And yes, i will do a 2 stage transmission in the swingarm if it's possible. But the question is: Can i have different speed and a large chain (like Bmx) ?
Thanks
Emoto said:Wheazel good to hear, can you share your performance details with the rv 100 , what type of bike/riding conditions ect... as for a downhill frame type build i cant but think a rv100 might be all one would need, as a rv120 on the same frame might be a beast 8) .
Mounting - Good question! short answer, 2 mounts are better than one - of course, especially if riding off road and mounting on swingarm = more vibrations, but generally from what ive seen many have got away with the standard single mounting, method, but no 2 people ride the same, an indicator might be short term bearing life closest to mount.
On a motorcycle id be tempted to use 2 mounts.
macribs said:Would you mind posting a pic of you setup, or a link to the clutch?
panurge said:Hello Livetek
Note that The Revolts are actually outrunners and your 120-90 is a faster motor, useless for a direct drive we are talking about, but good for a 2 stage transmission.
I Agree about the HK motor at least that's what it seems by other user's experience, since I've used an 80-100 only... about the statement on single stage VS 2 stage, although could be right on words, it is often not supported by real facts. I have an astro 3220....with 2 stage. Please point me to a central motor slow enough and powerful enough (>4,5kw continuous aand 7-8kw proven peaks), in <4 kg of mass to be a single stage substitutor for my Astro (actually 1,9kg motor, 4,5 complete trans including chain and sprocket)flathill said:panurge said:Hello Livetek
Those 120-90 hobbyking style motors suck (or at least they used to). Really high no load losses. Search here. The smaller 80mm hobbyking outrunners are better for some reason (thinner lams, smaller bearings, thicker magnet backing, etc)
In any case find the right motor for the job. A reduction is not the way to go even if it looks cool. It seems like you are saving weight with a smaller motor and higher rpm and more reduction but if you add the weight of the second stage back into a larger motor you get the same overall torque with with much more motor mass which means way more continous power handling
Absolutely not true.flathill said:panurge said:Hello Livetek
recumpence said:if you remove the spring weights, the clutch response will be far better. Your controller will survive just fine assuming the clutch does not lock near zero rpm. However, clutch engagement at a very low RPM is best for an electric system.
recumpence said:Absolutely not true.flathill said:panurge said:Hello Livetek
recumpence said:Wow, I am so tired of this crap being thrown around. You need to compare apples with apples.
Assuming identical efficiency motors, high power with low RPM requires far more copper fill weight than the weight of a well designed reduction unit with a smaller high RPM motor.
Also, gear whine is the reason belt drive is beneficial.
flathill said:recumpence said:Wow, I am so tired of this crap being thrown around. You need to compare apples with apples.
Assuming identical efficiency both motors will produce the same waste heat and both systems did produce the same peak power, the larger motor will be able to produce the near the peak power for longer (thermal mass and surface area). One less stage of reduction also means higher overall system efficiency. You could build the smaller motor with one stage of reduction if you had the space, but it would still have a higher reduction ratio, and the smaller motor would still have less active motor weight (copper, etc). Whether both motors have liquid cooling, or both are air cooled, the same limitations apply.
It all comes down to sizing the motor for the application, it seems
panurge said:There are pro and contra in both the approaches...and there are fields in which the single-stage-bigger-motor way should result, as for many aspectscin theory seems, the best one. But there are fields in which for many reasons, actuaĺly, you cannot equal the mass/power ratio of a 2 stage trans with a fast motor and/or the way that ratio is usable on a LEV, or, better, a bicycle.
Again please point me to a motor in the 3-9Kw range that works on a single stage trans at a reasonalble tension / current with a power factor similar to a 2 staged fast motor (astros ecc.). We are speaking of motor plus a complete trans till the wheel and any cooling system...
What I cant understand is why someone attempts to universalize his personal experience and point of view, or even a particular proven scientific statement but based on a single variable, and apply it to everything, and try to persuade everybody.
flathill said:panurge said:There are pro and contra in both the approaches...and there are fields in which the single-stage-bigger-motor way should result, as for many aspectscin theory seems, the best one. But there are fields in which for many reasons, actuaĺly, you cannot equal the mass/power ratio of a 2 stage trans with a fast motor and/or the way that ratio is usable on a LEV, or, better, a bicycle.
Maybe the Joby JM1S? What are you looking for exactly?
Astro's are awesome little motors. Very high quality and smco magnets
http://www.jobymotors.com/public/views/pages/products.php
