recumpence
1 GW
OK, progress is being made!
Power up is done at zero throttle. That is the way I have the ESC programmed.
Matt
Matt
thanks for the inforecumpence said:ev_nred said:the max voltage is 50v he is ruining 44 volts still room for one more cell
No there isn't. 44 volts is "Nominal" voltage for a 12S pack. However, they are 50.4 volts hot off the charger. Everyone merely calls a 12S pack "44 volts". However, they are really 50 volt packs when charged.
Matt
FebruaryFor Wye you tie all 3 of one color wire together (say the RED wires for sake of discussion). So, all 3 red wires are tied together in one bundle and set to the side
Jeeesh I put heat shrink on each red motor wire, then bundled 'em, placed a larger heat shrink around the bundle of 3 and placed 'em aside. The red wires are effectively insulated from each other. I thought 6 wires were for Delta and Wye only needed 3. A simple assumption in a blind spot when trouble shooting. A case of picture/diagram being worth a thousand words. Oowch, kicking myself.For Wye configuration, the 3 positive wires are tied together, and the 3 negative wires go to the controller. These 3 negative wires are the phase wires, just like in a hub motor
Guaranteed it will be something simple and you will kick yourself when you sxolve the problem...dont you hate that LoL
Hey Matt, Y-pedal, experts, what'd I blow (hopefully it's the stock CA 45amp shunt).also.. the CA shunt will not do.... you need a " real " shunt for over 100 amps ! ( it's ok for testing, but not for racing )
recumpence said:Hmm, maybe bypass the shunt and test it.
Matt
