Hi,
I need to shorten the axle on my front hub motor, it protrudes about 1,5 centimeters out of the dropout on the fork. It's a small hub motor (36V/250W, likely bafang 8Fun?) im trying to mount on a very (!) old linkage fork. I need to remove the protruding part of the axle.
Reason behind this is the narrow dropout on this 50+ year old fork and the fact that this ancient bike has only one front rod brake that doesn't really work well. I decided to go for a disk brake adapter that mounts right outside of the dropout and then attaches with a clamp to the fork to hold the brake. This is why I can't have the motor axle protrude there, the disk brake won't have its lower mounting point.
So in short, can I just saw that off? On the other side the cable comes out and I'm not messing with that. But as far as I can tell one side is just a threaded axle coming out, can i cut that off or are there any components that the motor needs to operate? Is there any reason not to saw off the protruding axle part?
I attached a photo of the part I want to remove.
I think most people wouldn't advise doing something like this in the first place, but I'm looking forward to hearing your thoughts. Thanks in advance.
