Hi veloman
Yep the rpm's are not optimal..A 750 watt motor with 11T turning 80T sprocket (36v 1000w controller) driving a 22T crank chainring turning a 11T-34T cassette 26" wheel does work okay without pedaling, and keeps the speed in legal (BC, Canada) 30km/h range.. my bike has two front chainrings.. the other is an 38T, I road this setup for the entire winter... the 38T chainring slows the rpm's way down, and not very fun to ride unless your interested in cardio training & enjoy pedaling hard at maximum cadence in every gear... I could keep up to most road cyclists on flats and hills..but in hotter temps. motor will overheat & be destroyed! - The Nano-tech battery is just so feckin powerful.. I had no motor overheating issue's with lower priced lipo..
My new 1000watt motor also has 11T sprocket.. however it has massive torque compared to the 750w motor..
a test without pedaling I reached 45km/h in approx. 18 seconds...
with pedaling I reached 50km/h in under 10 seconds...
However, I'am working on two big improvements which will give the rpm's a BIG boost..
- custom motor couplings 8T and 5T sprockets..
- 3 chainring crank setup: 18T - 30T - 42T..
I've read for every tooth subtracted adds approx. 10% more torque. From my previous builds I was able to reach 50km/h with a 750w motor on just 24v (750w controller) w/pedaling using a 5t motor sprocket to 80T drive on a 42T chainring powering a 11T gear 26" wheel.
