so could you set up..where you possibly have 3 12 volt lifepo batteries..you use one panel for each battery..cut around 18 volts open voltage amps max around 3. and then you use three separate solar charge controllers. you don't have to worry about over amping because the panels produce less than 5 amps which is okay for lifepo4... then you run from your batteries...a series to give you 36 volts nominal and then you hook this into your motor controller system?
the concept of being mobile and having limited or no need to hook up to the grid is eyeopening and juding from the lack of posting on the subject(from the web in general...you type in puff daddy you get a million hits..type in 36 volt lifepo4 solar charger you get maybe less than a 100 actual sites in English) it is uncharted territory. in a 36 volt e bike lifepo4 world. there are probably a million or so people in America that could bike 100 or so days a year instead of using their car if they had similar type technology, which seems buried deep in the net.
I like this concept because what if there was no powergrid where you choose to live.
ive also looked into making a winch for my bicycle. once again almost no posting on this topic,if you want to keep your winch less than 30 pounds and don't require 2000 pounds of pull power more like 75 kg.cf stall. this will help me choose more locations where I can take my bike also you could hide the bike in a tree with camo and then use it when you needed it. assuming the marriot or Hilton was booked up ofcourse....and assuming they had a solar array there that I could hook up my lifepo4 battery too. I honestly feel some people on this thread should start a new thread called solar-cross hybrid e-bike but only a distance that they can go to and come back to their solar powered house. I hate to be so negative but its frustrating trying to look up this solar powered stuff and then to find blogs with advice that really isn't that helpful to the topic.
oh I got a Chinese supplier that says they will give me three 35 watt panels and lifepo4 battery with 5 amp solar charger. around 450 dollars us...but no specs yet could be chasing another rainbow,,but maybe 5 email later ill know more....
