eBikeaholic
I need to splice the 4-1 higo accessory cable on my ebikekit front hub motor build because the cable is too long. The bike has hydraulic brakes so I'm not using the brake cutoff switches.
I'm not sure if I should just splice before the 4-1 splitter and just keep the 2 extra cutoff plugs tied together, or if I'm better off splicing them out for a cleaner look. I can always just splice them back in if I decide to add break cutoff switches.
I haven't opened it up yet but assume I'll need to identify which wire is which. Will I be able to just test the continuity using the connector going to the controller? Has anyone been down this road with some advice?
