pucksterpete
Hey Peter, nice looking Mastech, how she working for ya?
Pete
Pete
Peter Sternersson said:Now the Kelly´s up and running!
I connected the speed signal input to the CA, to one of the hall sensors in the motor. Seems to work, it gives a readout anyhow. Might need to calibrate it some later.
One thing that boggles me is the shunt setting in the CA.
As I wrote before, I made my own shunt, just by soldering some measuring wires on to a piece of 8AWG wire. Connected it to my PSU and set it to a constant current of 8A. I measured the voltage drop between the two measuring wires, and with Ohm law, calculated the resistance to 0.2375mOhm.
But when I set this value in to the CA, it changes to 0.761mOhms or something like that. I´m guessing that the CA is not advanced enough to measure mOhms, and with no current flowing through the circuit, it shouldn´t be able to do a self calibration either to calibrate it correctly.
Can someone shed some light on to this?
BlackArrow said:Hi Peter,
Use the "High Range mode" on your CA from 0.0763 to 0.9999 mOhm, you are probably set on "Low range mode" actually is the main reason why your CA reset at 0.761 mOhm, a sort of default value in this mode when your shunt is too low, i personaly use a .250 mOhm shunt in this mode, also if you CA start to display strange Amps when not running reset the "Zero Amps" ont the advanced value of the CA.
Good day!
Black Arrow
Your are welcome :wink:Peter Sternersson said:That did the trick! Thanks a lot!
Peter Sternersson said:I tested the motor WOT in the air just now, 2,4A seems about right.
Peter Sternersson said:I haven´t made up my mind if I should use the regen or not. I did spend an extra 80$ on the regen version, and it would be cool to test the variable regen feature but...
Hmm, need to figure out a neat way to solve it.
