The ride is good, and nothing fell off.
Some wheel noise is louder, without the fender covers. I'll put those back on (or new ones, more likely) after I finish the work on the rack and whatnot. That way I don't set them on fire like I did when I welded on the rigthside dropout months back.
A very interesting and unexpected bit of data is that today's ride was an average of only 40Wh/mile. It was 45wh/mile on the way to work; I don't know what itw as on the way home separately, but it msut've ben a lot less, to average only 40Wh/mile, probably down to 35wh/mile.
This is a drastic reduction from the 50Wh/mile average I had been getting just prior to this, with the new tires (knobbies).
And I have no idea what causes it :?
Well, not NO idea, but I don't know what actually does cause it.
I know the knobbies ahd been rubbing on the frame, but taht wasnt' the cause, becuse I'd been getting the same kind of wh/mile with the other tires that werent' rubbing.
I suppose it could've been something with bearings in the 9C, but I would imagine that wouldn't just cure itself with the new dropouts/etc., and even if it did, that's kind of a lot of power to be wasted inside tiny little bearings--I'd epxpect them to be pretty hot and I don't recall them ever being hot.
It's not weight; if anything it's a bit heavier now.
Maybe it ws a combination of things?
Well, we'll see if this efficiency change holds up over time; it's only been one commute so far.
Full data:
58.3vstart
55.6vrest
48.7vmin
4.575mi trip
3.424ah
183.29wh
40.5wh/mile
76.06amax
-14.1amin
20.1mph peak
14.4mph avg
18m58s triptime
Full data:
58.3vstart
55.6vrest
48.7vmin
4.575mi trip
3.424ah
183.29wh
40.5wh/mile
76.06amax
-14.1amin
20.1mph peak
14.4mph avg
18m58s triptime
