Grocery run today, so finally a chance to test just the trike, with the new tires, on mostly the same route I use for work commute, plus about a mile total extra (half each way).
These Shinko tires give a WAY better ride than any of the bicycle tires tried on SBC so far; even the manhole covers and grates that are 1-2" below the level of the asphalt are just bumps, and not WHAM WHAM canyons like they were with the bike tires. I'd guess its' the much larger volume of air, plus the thicker rubber and sidewalls, with the lower pressure, that is smoothing out the ride so much.
Another tidbit: While riding with the trailer and Yogi, I tested making turns at closer and closer to 20MPH, and was able to make left turns without slowing at all, and could make at least 17-18MPH right turns, depending on the intersection (some have too lumpy pavement, or loose asphalt, etc).
I assumed it was because of the trailer's width and weight and yogi in there, with the tongue holding down the back end of the trike--but I can make these same turns without the trailer, with or without cargo in the back.
I managed one right turn at 19MPH, just beginning to feel the rear end start to lift on the inside of the turn so I let off the throttle just an instant and it settled, then I hit the left throttle again to push me thru the rest of the turn (how I usually make my turns...motor on the outside of the turn with power, no power to the motor on the inside of the turn). This was after shopping, so there was a small load in the back of the trike, maybe 30lbs.
The wh/mile isn't noticeably different from the bicycle tires--about 48wh/mile for the total average trip.
Anyway, it is definitely an improvement with these tires.
