northernmike
Hey Matt, what's the BSD on those tires?
northernmike said:Hey Matt, what's the BSD on those tires?
kfong said:Thanks Matt, did you get the 5 or 6 turn version. So I can keep notes on your setup. I'm really thinking this might be a better route than the 600w BMC motor I was planning to go with on my mountain bike. Still undecided due to the work involved, but I do have my own CNC mill. Your power to weight ratio has me really interested, do you think range will be reduced due to the dual motor setup or are the efficencies good a well. Would like to know what your current draw is at just cruising speeds. If it's low, then you seem to have the best of both. I want a serious hill climber with lots of power to spare as well as the ability to go for long distances, say at speeds of 20-30mph.
They mention this version for ebikes on their site. 6turn motor
8120-6T Astro Monster 120 Brushless 6 Turn Motor
$399.95
I notice the shafts are longer, did you replace the ones on the original, if that's the case did you also replace the bearings. More details on what you did to the motors, if any please. The 4 motor mounts 6/32" was that enough?
How are you syncronizing 2 controllers. Are you just adjusting them so they seem to be putting out the same power or do you have a better method of dealing with this? I was thinking it would be possible to use a processor to monitor each motors current and throttle them up accordingly.
Kin
http://www.embeddedtronics.com/
kfong said:I'm really thinking this might be a better route than the 600w BMC motor I was planning to go with on my mountain bike. Still undecided due to the work involved, but I do have my own CNC mill. Your power to weight ratio has me really interested, do you think range will be reduced due to the dual motor setup or are the efficencies good a well. Would like to know what your current draw is at just cruising speeds. If it's low, then you seem to have the best of both. I want a serious hill climber with lots of power to spare as well as the ability to go for long distances, say at speeds of 20-30mph.
Kin
http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=8035&start=0... Anyway, with a 55A controller limit, this setup peaks out at about 2600W, but because of the gearing benefit of going through the 3-speed hub, this combo actually outperforms the 24s4p 72V 5303-based setup with a 4110-modded controller set to about 65A.
This surprising performance "boost" by taking advantage of the bike's gearing has started me on this quest now, to convert all my bikes to similar weight-saving configurations...
LiPoly powered 18HP Twin Motor Brushless MONSTER build!
johnrobholmes said:I used the 4035 on my first build. You will need a lot of geardown for it, and it got really hot while chugging up hills. You would be better off with a lower kv, maybe a custom wind. Something to keep it from bursting 120a when you hit a hill.
Miles said:If you don't mind waiting a bit:
viewtopic.php?f=28&t=9418
j3tch1u said:great work on the bike matt. glad the nimbus rim fit. i'm tempted to electrify my pk now. btw, i put in an order for an astro 3210 couple weeks ago. did bob mention what the differences were between the 8120 and 3210? if the 8120 is better, i may still have time to change my order.
GGoodrum said:Actually, they are exactly the same now. Supposedly before, however, the 3210s, which were $100 more, had tighter tolerences and better bearings.
-- Gary
deecanio said:yes good question, whats happening there Gary?
also a good question, being as matt is the first mounted, wheres our testing vid?
Cheers
D
