i modified the original schematic for the lv cutoff to show current limit resistors for the opto leds. i have not received an answer from microchip on the safety of operating without them, but it is true that the opto current could cause faster self-discharge for cells left uncharged for months.
when considering this, consider that the opto should trigger the ebrake line causing the throttle to be cut off, letting the cell voltage immediately rise well above the hysteresis point and turning off the opto. the circuit would then draw only a microamp until the no-load voltage drops to the trigger point, and i think if one lets a dead pack sit around for thousands of hours at that point that it is not a great idea no matter how the bms behaves. in practice i think that if a resistor is chosen to set 2 ma or so at the trigger voltage that it will not affect the self-discharge of a dead pack that much. when the voltage drops below the point where there is enough led voltage to bias it on, the leakage will be very small.
the typical rated output current of the TC45 is 7 ma and that is lots more than is really necessary to turn on the optos i specified, so the resistor will probably be a worthwhile investment, at a couple of cents extra per channel. it would certainly increase reliability, and that is always a good thing. i mentioned in a previous post how to calculate the resistor at different trigger voltages to produce the required led current.
the optos i mentioned can handle 70v on the output, so pulling them up to 15v on a typical controller ebrake line is not a problem but i would not pull the output up to the battery voltage if it is over 48v.
