With the help of my friend kfong and his awesome CNC-fu I'm close to completing my first eSkateboard build. It's an 8S setup with the 4.4kW kit from Alien Power Systems. It's my intention to mount the tupperware container just below the deck which should give just enough room for the power mains to connect to the ESC. Any suggestions on how to hang it so it doesn't interfere with board flex but still be accessible? I might try to find a better case at a later point in time.
Unfortunately I'm having an issue with the Alien 150A dual ESC. On 4S, both motors run, but when I attach the second battery (8S), only the left ESC will spin its motor. The right ESC either doesn't initialize, or initializes but doesn't respond to throttle inputs. I've tried running that ESC by itself but the result is the same, that is, it works on 4S but not 8S. The left ESC works fine on 4S, 8S, alone or when both motors are connected (to their own ESC outputs). I tried using both Auto cell count and forced 8S count in the ESC configuration with the same results.
Any ideas on what else I can try? Both ESCs are configured the same way with the programming software and are running v4.5 firmware.
-Wayno
-Wayno
