CONSIDERABLE SHOUTING
- Joined
- Jun 15, 2019
- Messages
- 809
https://www.ebay.com/itm/2941974475...aultOrganicWeb&_trksid=p2563228.c101113.m2108
I'm plotting a battery pack for a first all-custom machine and because of my space requirements, it seems like the 26650s are the best bet. In using a combination of the Battery Package Calculator app, and a battery configurator, I found that both the cheapest AND best-power LiFePO4 pack I can build will either be from these K2 cells, or A123 cells from servers. The pack will (arguably as you'll see) be a 20S6P with both packs easily maxing out a Grintech Frankenrunner controller (my baseline). My questions for ya'll are however:
Stats calculated so far are:
ANR26650 M1B
• 2600mAh Per cell
• 8.25 Watt hours
• Max Continuous Charge 10A, Recommend 3A
• Max Continuous Discharge 50A
Can be bought as salvage from Battery Clearing House, though their shipping leaves something to be desired. If bought from them, estimates say the price of a 120 cell pack would be ~$160 at a price per 1Wh of 0.154.
BATTERY PACK CALC
Voltage 66v
Capacity 15.6 Ah
Energy 1.03 kWh
Max Con. Discharge Current 300Amps
Weight 10.5Kg
Cost (new from maker) $665
Price (New from maker) for 1Wh: 0.646
K2 Energy LFP26650E-3800-21-
• 3800mAh per cell
• 12.16 Watt hours
• Max continuous charge 3.8A (1C)
• Max Continuous discharge 12A (4C)
Bought from eBay reseller, which is sketchy and source/data sheets must be verified. Sold in what seems to be “lots” of 20 cells per package, so will need 6 packages for a total cost of ~$120 before shipping. Versus the ANR server cells, these trade absurd discharge current for more capacity to a pretty impressive degree; nearly 1.5kWh pack, and possibly even cheaper than buying used cells from Battery Clearing House. With using XT60 battery connectors, it may be prudent to use a pack that physically cannot discharge enough power to met the connectors...
BATTERY PACK CALC
Voltage: 64v
Capacity: 22.8Ah
Energy: 1.459 kWh
Max Con. Discharge Current: 72A
Weight: ~10.5Kg (Estimated, no weight on these known)
Cost: ~$125
Price for 1Wh: 0.086
- Has anyone bought these cells, and if yes can you tell me if they were in good shape or not? The price is simply too good not to try.
- I can only fit a 20S 6P pack by allocating 5mm of space between my cells and the bike frame. If I went for the A123s I could give far more side-space at the cost of going to a 20S5P; do you think 5MM is WAY too little space, especially as a newbie?
ANR26650 M1B
• 2600mAh Per cell
• 8.25 Watt hours
BATTERY PACK CALC
Voltage 66v
Capacity 15.6 Ah
Energy 1.03 kWh
Weight 10.5Kg
• 3800mAh per cell
• 12.16 Watt hours
BATTERY PACK CALC
Voltage: 64v
Capacity: 22.8Ah
Energy: 1.459 kWh
Cost: ~$125
