Hi,
I run a BBSHD with an external controller. I used to run it at 3KW, but recently found out that 60 amps at 84V is loads of fun! The only problem is that the motor gets really hot. I have attached a few heat sinks on the bottom of the motor, but it still gets hot.
Thought about attaching a PC water cooling system to the bottom of the motor instead of passive heat sinks. What do you think? Any other ideas?
https://www.aliexpress.com/item/Alu...050.html?spm=a2g0s.9042311.0.0.6d664c4doa5zBk
