Hello,
I intend to use a BBS02B 500W mid drive. I have already good batteries from other bikes so I prefer to use 36V.
The Max RPM on the 36V kit is the same as the Max RPM on the 48Volts Kit?
The descriptions are somewhat confusing, they show same torque and same RPM (e.g. 100-130) for both kits.
We know less voltage means lower RPM, and I was already burned with a Hub motor rated at 36-48V and xxx RPM, to find out that the RPM was rated at 48Volts!!!!! The motor was OK, but too slow for me.
Anybody from experience of maximum speed of a BBS02B 3500W 36Volts installation versus a 48V.
I do not want to spend extra $$$$ for brand new 48V batteries unless the max speed (RPM) is too small.
Thanks for your help and advice.
