I like Chalo's lathe. :thumb: It's a perfect example of what I'd recommend for hobby use. I've actually used the same brand in the past.
There are several flavors of gaffer's tape that work very well in those applications. Lately I have been using Welstik, a brand of gaffer's tape that is unusually strong.CONSIDERABLE SHOUTING said:Also to add onto Chalo's comment, Duct tape doesn't like UV light and dries out quick. Not sure what to replace it with- aluminum tape for HVAC?
Chalo said:How did you keep the tape from flapping/buzzing/shredding? Did you back it up with anything stiffer?
You won't need the 'concentric rings'. The tapered lug nuts are more than sufficient for centering the rims. BTW, my 88 Toy Corolla SR5 has the same 4x100mm lug pattern.The Mini Cooper wheels are said to have a 56.1mm bore whereas the Mazda 2 has a 54.1mm bore, but i can use a hub centric ring to make up the difference.
... it's the tooling!
I am guessing you are just talking of the wheel RIM weight ?…excluding the tyre ?Scenario B: i use 2006 era Mini Cooper wheels which come out to 12lbs each, so i have a wheel weight loss of 32lbs instead.
If so, i am sure you realise that the tyres themselves will weigh more than that (20-25 lb each) and have a much greater dynamic inertia effect as their weight is mainly on the perimeter.
have you investigated different tyre options for both weight and low rolling resistance ?
maybe a set of rims and tyres from a Prius or similar will fit !
Yes.Also think alternator works more when car is coasting.
So... how about a simple NC (normally closed) reed switch (or momentary toggle SW) on the accelerator pedal, or throttle linkage somewhere under the hood -- coupled in series with the alternator's field excitation lead? Switch closed (charging) when idling... open (no charging) as soon as you begin accelerating. Doable for city I would assume, but you'd likely need another simple circuit to detect low battery voltage and overide the throttle switch on extended travels.I doubt you could replace your alternator with one of the smart units as you would need the comparable ECU and firmware..but anything is possible.
Took his advice and ordered the 21lbs lightweight AGM battery. Maybe the next time i buy a battery, we'll have LTOs on the market, but for reliability reasons, i'm uninterested in being a guinea pig since this is a daily driver and not a race car.
He is BS ing you .Had a good call with the braille sales dude, really friendly and informative. He advised against a lithium battery because this is a daily driver and if the lithium goes flat, it's possibly toast.
To be honest, I don't know how much of a project it would be to strap together five of these:
add a balance board, and mount it in a foam lined box. I'm waaaay too apathetic about cars to do any such thing to my own household mule, but if I didn't hate it, I'd probably hack out a battery like that.
You need to find a better battery supplier if that is the level of his advice and knowledge !The batteries are designed for race applications and all out low weight, and not daily drivers.
