Hello,
I am experiencing an issue with my Ebike and am seeking assistance in diagnosing the problem.
Current motor in use: MXUS 36V 350WCurrent controller in use: KT36SVPRD-C8W02C
Problem: When pulling the throttle, sometimes there is no reaction whatsoever. Other times, I hear the motor starting up, but even when the motor starts, it doesn't spin. The system is showing Error code 01 or 06.
It was working fine until I was riding uphill while pulling the throttle, and all of a sudden, it stopped working.
Any advice you can provide would be greatly appreciated.
Thank you in advance.
according to my user guide
Error code 01 : Throttle lever problem
Error code 06 : Controller problem
Edit : Do hear drum like noise when I start, and unable to do a walk mode either, anything relate to motor doens't work
but I do hear motor getting energy.
Edit : checked brake levers are fully shut or not, doesn't seem to be brake issue at this point.
Edit 3: I am reconnecting every wire and checking phase wires once more, will update the problem any assistance would be greatly apricated. thank you
