Jamil.Siddiqi
- Joined
- Mar 19, 2019
- Messages
- 31
I am in the middle of a 26" --> 19" conversion and wanted to share some interesting findings:
- started with 26" stock MTB wheels, with 28mm Continental street tires. Max speed at 70kmh (maxed out RPM of motor). Cruising speed around 60-65km/h. Continuous pedaling is tough because of pedal RPM beyond around 45km/h (with 50T chainring)
- changed to 2.75x21" knobby tires (Shinko). Max speed at 65kmh (maxed out power of motor). Cruising speed around 55-60km/h. Battery range reduced by around 10%. Pedalling at 50kmh is still comfortable (now with 52T)
- since I get a lot of flat tires, added a Mousse tube in the rear. A bit too soft for my liking, but very comfortable. No more flats! Max sped reduced to 60km/h, cruising speed 50-55km/h. Battery range reduced by another 10% to about 33km --> now I run out of battery regularly.
- acceleration has been greatly reduced as well. I am very surprised that the softness and added weight have such an impact on acceleration.
- given the stability I will not go back to bicycle wheels anymore. I have a much better sense of safety with the MC wheels. 65kmh seemed quite fast and instable with bicycle wheels (specially with potholes, manhole covers etc), while the same speed is really comfortable with the MC wheels.
Now I have ordered an 19" wheel and tire to check impact on weight, speed and range. I will be trying out the Tubliss system instead of Mousse. I will be adding some fairings as well, to check the impact. I have also ordered a 85T (monster) chainring, so that I can pedal as much as I like.
Facts about the bike:
52V, 28AH, 1500W hubmotor, weight around 24kg with 26", close to 40kg right now. I am at 90kg including backpack.
