Rix
100 TW
As you are aware Amber, the industry metric size references are as follows for the 90/80-16. 90 is the width in MM, 80 is the percent of the height off the bead of the tires width, and the 16 is rim size. So we get about 3.5" of width and about 2.8" of side wall height on a standard 1.60x16" MC rim. Now if your rim is narrower, the tire maybe a little taller and less wide. Conversely if the rim is wider, the tire will be a little wider and slightly lower in sidewall height. On your 2.5-16 tire size refernce, we are missing the sidewall percentage height information as is the case with all tires that are size reference in inches instead of MM. That said, I know from personal experience with various trials and knobby tires from 2.5 to 2.75 wide also runs around 80% of its, except the Michelin M62 Gazelles series, which is more like 65-70%, we can figure out the difference. So my math tells me your 2.5-16 inch tire has a sidewall height of about 2" or so. Based on that, we should see a radius increase of about .8 for a total diameter increase of about 1.6". Thats my best educated guess Amber.
