The reason for moving 2 sla's to the front was to get the front shock to work better. It hardly moved at all as all the weight was all on the back. Just because you have a front hub motor doesn't mean anything as the fork sits on top of the motor; with no weight on it. I contacted the manufacture and they don't make springs for this shock as its an "entry level" shock and all that is available is a seal kit; so the guy says. Anyway, all it has is a medium spring. I'm a little lighter then medium. I read a review on this shock and a guy said that if your over 200 lbs to not use it as its not stiff enough. Well, I can say that it works great for someone at about 175 lbs (sla's included). Now that I moved 20 lbs of sla's to the front, it does work like its suppose to. Anyway it came out pretty good. Here's a few pictures:
