TotalConfusion
Hi all,
Well last night i got back from a ride and put my bike back on charge and charged it too 86 Volts (90%). All seemed to be ok because i went back out and turned it off about an hour later and it was at 86.1 volts so i pulled the charger from the battery and then turned the charger off as the green light was indicating it was charged and it was.
After disconnecting the power lead from the charger i put the lead next to the charger and closed the BBQ lid and went inside after locking my bike up.
This morning i went out to unlock my bike and go to the shops and off i went. on my return i plugged the charger back into the power supply and turned it on but i noticed none of the indicator lights where on which doesnt normally happen. I plugged the charger in to the battery and still no lights or power.
One other thing i have noticed is when i plug the power lead from the charger into the power Supply i get a rather large spark at the plug which has never happened before.
The Charger is a 21S 88.2 volt from EM3EV and to date it has done about 25 cycles on my battery with not a problem.
What i would like to ask is how do i diagnose this and i know ill need to pull it apart but i have no idea what i should be looking for at all.
WHERE DO I START PLEASE?
Ill post up Photos of the charger once i start pulling it apart or does this come under warranty as its now 6 months old.
