litespeed
So I can't figure this one out after simulating time and time again. My DH Team bike I want to use for 70% Katy Trail and off road and 30% on road. I don't need to do 50 through the woods but want some big time torque so I'm thinking 3525 on 100 volts with the possibility of going to 125v. which would give me roughly 40 and 50 mph respectively. At a top of 50 amps gives me about 107 ft lbs of torque on either voltage. Now if I throw a 3540 in there at 75 and 100 volts I get top speeds of 43 and 53 ish and torque drops to 81 and 86 ft lbs.
I have a BMC V2 Speed with the 3 gen gear set and on 75v 15 ah at a max of 20 amps I get a top speed of about 32 mph and 65 ft lbs of torque. Going to 30 amps ups the levels to 35 mph and 82 ft lbs but I assume a very short life awaits that system. I have never exceeded the 20 amp range.
So if I wanna run the trails at say 25 ish mph 70% of the time what motor would be best for me? What have you guys found out with these motors in your bikes? Heat and longevity being the biggest factors I'm looking at. I need some top end for street use to get me out of harms way when I need to. The 3540 has way more torque at 30mph than the 3525 does. Never really paid attention to the slim "power band" each motor has and where it's at before.
Not sure what else to ask? I thought about the 4065 but don't want to be limited to a single gear in back.
Tom
Tom
