El_Steak
So you have only a couple 45 amps Anderson contacts to install and you don't want to buy the 40$ TRICrimp tool?
The 15 and 30 amps are easy enough to install with standard tools and a bit of solder, but the 45 amps connectors are different as they have flat sides instead of rounded ones.
I came up with the following trick to install them. If you have a better way, let me know.
1- carefully place the edge of the contact sides in the little V grooves of your pliers
2- slowly compress the contact. The 2 sides will buckle up and take a nice curved form. This may depend on your pliers, but works everytime with mine.
3- Insert the wire between the rounded sides of the connector
4- Close up the sides using standard tools
5- Finish the job with a bit of solder. Be carefull not too put too much or the contact won't fit in the casing.
