Greetings,
a newb here and I am looking to build a versatile Li-ion pack from 18650s to power a 48V 1000W rear hub bicycle kit. I would like the capability to easily remove defective cells if necessary. And also to have the packs wired in 12V configurations. Is this a problem for balancing?
The reason why I want 12V configurations is to allow for standard 12V device usage (camping etc, smaller draws).
The issue i am faced with is whether to use 3s or 4s. nominal voltages would yield 11.1V or 14.8V, respectively.
Also, what would be the appropriate way to match voltage to 48V motor? The nominal or full charged voltage? Which would yield 50.4V vs 48.4V for a 12S pack.
Advice is appreciated!
