I had a stock rad mini and have since upgraded all the electrical components besides the front and rear lights. The new controller does not have a wired light cable.
I have never completed a DIY electrical project. My goal is to wire up the pair of lights to my battery and add a set of usbs for the future where I can connect Arduino/GPS/etc.
From asking Reddit, I have come up with two conclusions.
1. either I try to wire a cable that comes out the controller(void warranty).
2. or I wire a 52v to 36v step-down with an LM2596HV
If I were to go with the latter. How exactly will I do it?
Here is the cable setup from my battery, on-off switch and lights.\
https://imgur.com/a/iiiFTzT
the lights are rated at 36v on the website but have a sticker for 48v. I reckon I should have the LM2596HV chip output 36V to be safe(Does voltage affect brightness in this case?).
E-bike 6-36VDC (Xe)
https://spanninga.com/product/axendo-60/
photos of lights taken apart
https://imgur.com/a/1QNUQNo
From my understanding, this is how I should set up the components
1. Connect the battery to LM2596HV from the cables included in the photos above(Add fuse?).
- not sure what output current I should set
- could i add a 36v to 5v step down here to wire in 5V usbs/alarms/arduinos/gps in the future? Or should I use the left over 54v female plug and connect it to another LM2596HV to 5v
2. connect Switch(connected to the 58.8V MAX stepdown only
3. Front Light
4. Rear light
5. Then to the black wire from the battery
(not exactly sure where the red and blacks go.)
E-bike 6-36VDC (Xe)
3. Front Light
4. Rear light
