https://lmgtfy.com/?q=cav3+grin+specs&s=gdetrailers said:The other device the CAv - how much space does that take up?
Dui said:You can also check your wiring and see if your controller has a "smooth start" wire.
Some of them do, the purpose of it is to limit the power at startup so that it is less jumpy.
I can't see much in the picture you posted, it is way too small.
Also, before doing any mods, I suggest you to check your throttle. It's not entirely impossible that your throttle is defective. Not sure if your current one uses a hall sensor or a potentiometer, but if it is the latter than it sometimes happen that there are some dead zones on the pot resistance. Could be that, in your case, the dead zone is at the beginning, so the first few degrees of twist are not seen by your controller. It is very easy to check, either with a multimeter as suggested earlier, or just with any random potentiometer you can find around, or, even better, with an other throttle.
detrailers said:P.s. a little bit of trouble finding at 1k 10 turn pot so I got a 1k 15 turn one, I hope that's ok
I'm confused. I was asking about CAv3 doingfechter said:Yes, the CA allows adjustable ramp rate. Some controllers are programmable where you could fix it in software. Old school controllers will have a small capacitor somewhere on the board that controls it. But if you don't have the programming software or don't want to try messing with the controller circuit, then the CA is a fairly easy solution.
john61ct said:ramp mapping / curve adjustment
and the response I got:
> There is no curve adjustment in the CA
Are these different things? Please help me understand the terminology.
could I know the fork dropout size? is that 144mm or 135mm?Dropped pan 2" to accomodate bigger batt and controller, still have 2" ground clearance. Also had to rework rear frame upright to accommodate disc and cally. Next up ill be making the mount for caliper and welding up unused holes and then final weld and grind and off to powdercoat.
