leelorr
Hello,
I am thinking of building my second E-bike (the first was a BBS02 750w mid drive) and I am thinking of experimenting with a stealthy sine wave hub motor build for a change. I have read many posts here about the Q100 and Q128 hub motors for low powered use and have a couple of questions:
1. I have read in a few posts that the Q128 motors are much noisier than the Q100 motors. Is this true? If so, is it because of the greater internal gear reduction in the Q128 motors? The Q100 motors are only rated for 350 watts, hence the interest in the Q128 instead.
2. I am thinking of converting a mountain bike that currently has a seven speed rear derailleur, which should be compatible with a Q128H freewheel motor in 135mm. I am interested in using this motor if possible because it is rated for 800 watts instead of the Q128CST's 500 watt rating. I have read that the "freewheel" motor versions have much worse gear shifting behavior. Is this true?
Thanks for your help,
Leelorr
Leelorr
