John Bozi
Pendrag can you measure the width of your shock and tell me exactly where those adjustment nozzles point out and if forwards how far.
Yeah mate when I get home I'll do dome photos with a ruler.John Bozi said:Pendrag can you measure the width of your shock and tell me exactly where those adjustment nozzles point out and if forwards how far.
19531 ZIPPY Flightmax 8000mAh 6S1P 30C (AUS Warehouse) 8000 30C 1220g OK
35548 Turnigy nano-tech 8000mAh 6S 25~50C Lipo Pack (AUS Warehouse 8000 25C 1105g OK
35468 Turnigy nano-tech 6000mah 6S 25~50C Lipo Pack (AUS Warehouse 6000 25C 908g OK
14715 Turnigy 5800mAh 6S 25C Lipo Pack (AUS Warehouse) 5800 25C 929g OK
19522 ZIPPY Flightmax 5800mAh 6S1P 30C (AUS Warehouse) 5800 30C 838g OK
25445 ZIPPY Compact 5800mAh 6S 25C Lipo Pack (AUS Warehouse) 5800 25C 843g OK
pendragon8000 said:OK. I see your point about sag. Let me put it to you like this...
You can pull about 2kw at the moment?
So I you pulled 2kw from 25c zippys 2000/72 =28amps
If you pull that sort of power from those they will hit low voltage alarm after delivering 75-50% of rated capacity after a few months in sub 20°c weather. So you may need to pull power consumption down using the CA just to get the capacity from the pack. That's why I recommend 40c turnigy blue they won't sag to low voltage alarm after half capacity is used so easily.
Also the quality control on those is much better and all cells should be identical.
Cheaper ones have inconsistent capacity and internal resistance. So 1 cell might sag much more than others, or earlyer, activating low voltage alarm.
If you want only 5ah 1p you better make it a good pack u less your happy with 1kw of power after the first few km.
If you had a mid drive or geared hub that would be different. 4065 is thirsty.
Will operate a bit like a rear light but I reckon will look bloody awesome.When it is dark and your wheels start to move, they automatically light up creating light that appears to hover above your wheels.These lights are flashing
When you stop they will switch off to save battery powerAUTOMATIC: with light & vibrancy sensors, automatically light up ONLY when driving & in dark, and off when parking and in daytime
Weight: 320g =0.75lbs
Eye to Eye: 190mm=7.83"
Travel: 50mm=1.97"
Hole: 8mmx24mm
Damping: 3 System
Adjustments: Rebound, Lockout, Adjust High Pressure
Damper Shaft: Steel
Valve Angle: 30 Degree
Shock Body: Dark Hard Anodized Aluminum 6061
Spring: Air Spring
Intended Use: All Mountain, Freeride, Downhill
Made in Taiwan
Warranty: One year
pendragon8000 said:so to full charge balance use the bc168 http://www.ebay.com/itm/AOK-BC168-1-6S-8A-200W-Super-Speed-LCD-Intellective-Balance-Charger-Discharger-/150735495200
i use 2 of these to charge my monster bike battery 2 quaters at a time (half at a time).
this charger requires a hefty powersupply to run properly:
http://www.ebay.com.au/itm/like/181232440145?lpid=87 there are other no name brands if you want to save $20 but i had one sent to me with the voltage set to 110v and blew a fuse when i pluged it in. easy fix (for me) but if i was you buy the brand name psu(power supply)
ok so that can charge the batteries through the balance leads:
you have 1 of these per pack and if you want to parallel multiple packs you need to get the parallel lead for that and charge through it to chrage that parallel group at a time. eg 18s 2p, 6 blockls of 6s grouped in pairs with paralleled balance leads connected to cell monitors or charger.
parallel leads:
so then you wan to put the 3 paralleled 6s into 1 big 18s... its best to make a plug that can connect them in series and then connect to your controller, preferably IMO with a precharge resistor so no sparks to freak you out or wear out the connector. anderson powerpoles are good cos they plug together like lego and you can make the plug how you wan. eg 6 negative nd 6 positive from the battery then on the other plug the first positive and last negative (or vica-versa) have wires going off to your controller plug with 75v HOC(hot off charge) and the other andersons pp plugs series together:
battery1 + to controller plug +
battery1 - to battery2 +
battery2 - to battery3 +
battery3 - to controller plug -
you can just hard wire them but then you cant parallel charge the battery pack, but i would advise against that for a you with less electronics experiance. parallel charging with the bc168 can lead to trouble if you forget to disconect the series connector or if a plug is dodgee you will not charge all the cells but they will appear to be charged with 4.2v across the screen on all cells.
if you use a bulk charger that runs 900watts you can disconect the controller and plug that in to power up your cells the same way you charge your battery now. just check that the cells are of simalar voltage (balanced) regularly so that no cells over charge and explode or catch fire. bms-battery has these:
http://www.bmsbattery.com/alloy-shell/457-alloy-shell-900w-lifepo4li-ionlead-acid-battery-ev-charger.html
i have the 1200watt model and its over kill. charges so quick its probly not good for the cells and its a bit too big for a back pack. 900watt would be quite fast still but fit in a back pack.
you can charge with only a bc168 or an RC charger but it takes 3 seperate charges to do it.
i think the best option is bulk charge and balance charge each of the 3 pairs. this would take about 1hr unless you really flatened the battery it might be longer.
rc chargers are unreliable from what ive heared, they arent deisghned to charge the sort of capacity we use and burn out pretty quick. although the more expensive ones like "turnigy fat boy work station" and "icharger 3010b" may be reliable and powerfull. note those rc chargers will NOT charge through the balance leads only and require a conection to the main power leads so you would have to disconect everything, or when making the pack have extra conectors wired in.
info overload!
John Bozi said:
1.John Bozi said:pendragon8000 said:so to full charge balance use the bc168 http://www.ebay.com/itm/AOK-BC168-1-6S-8A-200W-Super-Speed-LCD-Intellective-Balance-Charger-Discharger-/150735495200
parallel leads:
info overload!
I really want to order a mini lipo kit asap, because the shock has been dispatched, and im not pulling anything apart until I got the lipo kit all together.
Ok 12s1p
1. so do I need to buy balance leads? I thought they are included with the battery.
2. If I buy two of the charger you recommend do I need two power supplies?
3. do you have a link to a power supply to use that will not blow a fuse?
4. What voltage is the power supply to be? Is voltage like what we use from the wall in the house? or the voltage that my pack will be running?
5. when the batteries are in 1 series do i need 1 cell monitor or 2?
6. What harness wire do I need to series the two 6s together?
apart from two batteries, moitors, chargers, power supplies, harness...
I will order xt150s, and the turnigy watt metre
anything else?
If your have a brew fb/skype us
While I'm working on the triangle I'll have two of these batteries
in this case that I already have (hopefully just fit)
(One Side Case): 168*125*50MM
John in CR said:laying cells down perpendicular to the frame is the hard way to try to fit Headways, because they're so long. In line with the frame will be much easier. Only a handful will fit inside the triangle, but with 1 cell width added to each side of the frame then you pick up a lot of extra space, since the inside of the triangle is no longer your size limitation. The cells can be arranged different ways or even angled, but here's just one idea.
the Super DUO needs 24V-28V of input voltage but can naturally also be operated on lower input voltages (from 11V).
Travel: 50mm=1.97"
Hole: 8mmx24mm
Damping: 3 System
Damper Shaft: Steel
Spring: Air Spring
Made in Taiwan
Warranty: One year
Wow you just gave me a huge summary of a lot of stuff I have done. A ton of questions I had to go through myself...efergy kb said:Hi John, been following your post with interest for quite some time and looking to get a similar motor.
I hope you don't mind clarifying a few questions.
- There was a point where you made a comment re: swapping the 4065 to the 3565 - this was probably in comment to the issues you were getting the motor within the 135mm dropouts? Why didn't you go for it?
-Was there a difference in top speed/ total V consumption that the 3565 was not able to achieve that that 4065 can?
- i have yet to read/ see any one so far who is able to achieve the 65km @48V!
- What was the max speed and average speed did you achieve at 48v 40A on the flat?
- Wires - did you end up having any issues with the clearance of the wires too close to the the heads of the spinning screws? or the brake able that was only mm off the motor? How did you end up resolving those issue?
- Add the extra washer to use the smaller cog - did that off centre your wheel? What was the issue being slightly off centred? Did it rub into any parts?
- How many spacers did you end up using on either side?
- 7spd freewheel - i think you put this in and took out the front derailleur & front gear shifter is that correct? From your last video you swap the rear gear shifter to the left side?
- Did you also end up cutting or swapping the chain because of the free wheel? You mentioned you did swap out the rear derailleur to 7spd.
thanks!
@J
