Yeah, but :lol:
I will just have to not go fast and keep your words in the back of my mind.
So you think the rear chain stays on BOTH sides are compramised, I agree as I did ride it and I did feel it move over a couple days of riding, thought it might have been loose fw, loose hub I checked by pressing top of the tire to feel wiggle and nothing.
My online classiieds guy is not responding, back. Today I emailed 2 motorcycle shops and one more one list to email. Those guys will be $100-$200 easy which could go towards another used bicycle.
Custom motorcycle shop wants $120/hour, will get them to throw in a bracing piece, might even get them to beef up the fork dropouts.
Later I may buy a 120V welder, but I may give the 6061 alum a go on my old dc only Lincoln arc welder, its just the family freaks out, its 220V and tons of amps. I could hook it up to the dryer outlet next to the attached garage door. Wife is afraid of my big heavy dc only Lincoln welder with lots of amps.
She freaked out the other day thought I had used it. I did when I first got it, did my first ever weld on it. Then it collected dust ever since. With covid, no one leaves the house so its hard to weld anything.
This 604 might be a good work in progress bike. While I was fixing the motor with new phase wires to winding wires, and putting it all back together so I could see if I fried my controller (which I didnt) I was thinking I could buy a 120V welder that does aluminum, all the cheapies are dc welders. The one yt vid I saw at Weld.com had a rear triangle frame and he only used 80 or 90A, I could use it for a few things like beefy up bike seat, weld the rear rack. I'd also like to get rid of the angled tubes for the triangle to have better fitting batteries.
I bought some 1/8 3.2mm Aluminum Solder Rod today for $14.99, figured I'd buy it and give it a try,see what happens. I scored on some other items at the store, old rusted out $9.99 ammo cans and a few other things. Its a temporary fix. First braze the crack, tomorrow hunt down 6061 to beef it up and the other side. Then at least I can ride, slow and take it easy on the bumps and curbs.
I am pretty sure I bought this item, as its the same price, 2 pcs
https://www.princessauto.com/en/2-pc-1-8-x-18-in-self-fluxing-aluminum-brazing-rods/product/PA0008471088
I figure I will take my rotary, make a valley on the crack and take off the paint around it then heat up the frame with my Bernzomatic Propane blue bottle, pic below. Will literally do all I can fit snuggly.
Metal Superstore has plenty of 6061, selection pic below. Rod, flat.
I may put in normal 26" x 2.50 wheel in the back so I can brace that crack area and possibly have an area for my 36V square battery. Maybe even a 24" wheel.
120V input 75A output might not be enough - https://www.canadiantire.ca/en/pdp/mastercraft-inverter-arc-75-stick-welder-0589862p.html#srp
These will go on sale sooner or later for 50% off - This ones DC not AC
again 120V input. https://www.canadiantire.ca/en/pdp/mastercraft-flux-core-125i-inverter-welder-0581926p.html?rrec=true#spc
https://weldingmagazine.com/how-to-weld-aluminum-with-a-stick-welder/
You need to have a DC stick welder. It works great for welding aluminum.
Might have to dust off my old red Lincoln arc welder and practice on 6061 before I do the bike.
Read the picture comments
nicobie said:
I've tried something similar and was not impressed. They kind of work but I doubt they would work on your broken frame. Personally I would not trust that frame anymore. Even if it was welded by a pro and the weld held, I'll bet it would break again right next to where it was welded.
It's time for another frame.
