There is a dmn shock just like yours in AliExpress that has a 750lb spring, the shortest it comes is 220mm.I have to do some work on my suspention, it is way too soft.
For the fork there was no problem to find different springs, they come in 5 options.
From extra soft to extra firm. No info on spring rate, but the stiffest is recomended for riders 90+kg, no mention of bike weight.
But I am almost 90kg, and my bike is about 60kg.. So I think the stiffest is what I want
I didn´t think finding a stiffer rear spring would be a problem, but it seems it is not so obvious as I thought.
I have a dnm burner rcp-2s, 200mm with 550lbs spring. I think I have seen those with 750lbs spring, but I have´nt found that now.
I looked at some other springs, but the stiffest was about 600lbs.
Does anyone here know of a suitable spring?
Great workThis is what I meant with that I had to offset the clamping bolts on the sprocket side:
And how it looks on the other side:
It looks a lot better after a little finishing work, a little sand blasting and some paint:
My stealth bomber Chinese model 8000w has 21” motorcycle time front and rear. So it does work, at least on mine it does.Man, you guys are making my buyers remorse even worse! lol I mean, I don't have the means to make an entire new swingarm...how much do you think a fabricator would charge me for something like that?
18" Tire isn't an option with them apparently. I tried asking the company to put a 21" on the front and a 19" on the back, and they're telling me no, the bike will not function, and I'm like say what? I don't see any hub rims that are cross laced in an 18" either. Should I go with both 19" and worry about getting a 21" later down the road? Maybe put a shinko 241 3.5x19 on the back? I guess I could ask them to ship an extra 21" wheel if they refuse to put it on themselves. I just don't get why they're saying no to that.
Also, do you know what the crank bracket size on these frames are? The crank they're putting is total garbage with a shimano touring tensioner. I was gonna take all that out and make it fixed with a 32T front sprocket. Does it need a chain tensioner?
Thanks, I bought the rear fender at some shop for vintage moped parts. I dont remember what it was for, maybe I have posted something about it in the thread?First I want to say Great Job. You have a lot of great shills and talents. I have an 8000w Chinese version stealth bomber like yours.
I have two questions first could you tell me where you bought that rear fender? Second would you consider selling me a completed rear fender like yours?
Also it looks like you did ok on the brakes I’m currently looking into upgrading to dirt bike brakes. But my first choice in bike brakes is the Magura MT7e there amazing. Of course if I were rich the best brakes in the world are the Trickstuff Maximum. But I’m not. Best of luck, even though with your talent and skills I don’t think you need luck, with you e-bike it will be a blast.
A lot of people are missing the most important thing regarding these stealth bomer clone frames concerning the rear suspension and achieving a decent level of off road handling anywayI have to do some work on my suspention, it is way too soft.
