ANT BMS ..PROBLEM?
The MOS and balance temperature sensors are integrated so they should be reading at the very least ambient temperature.
.019V may be acceptable at this low of a charge. Depends on what you have your balance set to.
Show what your parameters for more detailed answers.
later floyd
later floyd
have no idea what your talking about. Have a picture ir videi to help what im looking for.
Click or tap DeviceParam it should fill in many of the settings. You may have to click on the correct chemistry Liion, LFP/LiFePO4, LTO to have it fill in the settings. The Ant BMS defaults to Liion
What chemistry are your cells?
How many cells do you have in series? 16 so a 51.2V nominal LiFePO4 battery pack?
Later floyd
ok Li-ion 59.2V nominal
basic settings
Cell minimum voltage 3.0V
Cell maximum voltage 4.2V
Battery maximum voltage 67.2V
Battery minimum voltage 48V
It should be set up since it is a commercial battery.
If it is not set up I would contact the seller and ask them what the factory settings are.
later floyd
16S li-ion battery nominal is 57.6v not 59.2v
Just like 10S nominal is 36v, not 37v. And 20S nominal is 72 not 74v. Cell nominal voltage is 3.6v, not 3.7v
