Lurkin
emcee said:The weakest link of commuting by bike, are the tires.
I experimented with tubeless tires last year after getting a few pinch flats when taking aggressive turns.
I used Stan's no tube kits and had an annoying issue with leakage. Once a week or so I would have to top up my tires because they would be down to around 20 psi, seriously affecting my efficiency. My flats didn’t go away either. My tires are magnets for staples and small nails.
I have ultimately gone back to tubes using these thick mofos http://www.amazon.com/Kenda-Downhill-Bicycle-Tube-Schrader/dp/B00IFV7TJG .
I don’t have a problem with pinch flats. My tires don’t seep air, and if I do manage to pick up a nail it’s usually just a slow leak. Except for that one time I picked up a 2” deck screw.
I have used tubeless mountain biking and I definitely see the appeal of the weight savings and lower pressures, without the worry of snake biting your tubes. For daily commuting and road use, especially on an ebike. Good heavy duty tubes are my choice.
"Snake biting" and pinch flats are the same thing. Neither are caused by either tubeless or tubed. Both are caused by too lower pressure allowing the rim to 'bite' or 'pinch' between the road/surface and rim into either the tyre or tube, whichever is holding the air and pierce it, creating a puncture. The 'snake bite' pattern is when the bite/pinch has occured with both sides of the rim, creating a parallel set of holes.
Either way, its caused by the user not the pressure system.
If you are having problems with punctures, its a reflection of where you are commuting as the protection of your tyre/liner/tube must be sufficient to prevent puncturing. I.e. you need a puncture protected or thicker tyre and/or tyre liner and/or thicker tube and/or sealant. They are all offerings to solve this issue, although there is debate as to their effectiveness/ peoples preferences. I've always thought it was better to protect the tube via thicker tyres or tyre liners than going for thicker tubes, but if it works for you, I'd stick with it. 8)
