Okay read up a bit more on what would be required to register a vehicle as a moped in Oz.
Summary of Registration requirements for motorcycles, and mopeds
Here is my summary:
- would have to be
registered as an ICV (Individually constructed vehicle) for self builds
- requires a compliance plate for stock ebikes
- requires a number plate & registration
- tyres must have load and speed rating appropraite for vehicle
- no more bike tyres?
- need head lights between 500mm and 1400mm above the ground
- brake lights between 350mm and 1400mm above the ground
- one tail lamp not more than 1500mm above the ground
- one license plate light
- turn signals required
- horn
- at least one rear vision mirror
- mudguards
- chain guards
Pretty much everything a motorbike needs to comply to, an ebike over 200W would have to. If you can find someone to give you an approval certificate.
I don't want to build a motorbike.
I don't want to go that fast.
I want to still pedal and get exercise.
Surely there is some middle ground. Ebikes are one of the most efficient forms of trasnsport in existence. You still get exercise. You are still travelling at non-powered bike speeds. (I have been overtaken by a road bike while at full throttle on the flat)
The trick is really that bikes are a very priveledged form of transport,
- allowed on footpaths when you are young
- allowed on dual use paths when you are older
- allowed on roads without any registration
We don't want eBikes messing this up.
Maybe if we restricted their use to roads only, but increased the power limit to 500-750W.
Or/and introduce a minimum age for an ebike, similar to the rule that stops you riding on footpaths.
- Adrian
