Bafang extension cables
toureasyman
Is there an extension cable available for increasing the distance between the display and the buttons that control the display? I bought an extension for the speed sensor and it works just fine. Would that cable also work for the display to button module?
I think those wires between the buttons for the display and the display are fixed, I dont think there is a connector, but I am going on the basis of a KT display which I had then sold.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=Bafang+extension+cables&_sacat=0
The only other option is to unplug the display, splice the insulation off, cut each wire one by one, and solder an extension wire, remembering to use heatshrink for a nice clean look, or just some neatly placed black electrical tape will work fine as well. Hopefully they use different color wire, that is why I said cut the insulation off first. Then each wire, because maybe a wire has a cap on it with stored energy. Best be safe, not to ruin the electronics right.
Thank you for your reply. The 850c display does in fact disconnect from the button module. I’m just not sure if there is a way to extend it without the measures you propose.
Is this the cable you are after?
https://www.e-bike-technologies.de/index.php/en/extension-cables/extension-cables-signal/extension-cables-higo-mini-b-series/2-x-cable/higo-vk4-detail
Actually, I guess I found my own answer. Seller of my Bafang, after inquiry, provided me this link, so I ordered one.
https://sellercentral.amazon.com/nms/redirect/90a9c6e3-cede-35b8-8823-3539245ffa01?sk=nQYhlm3mhZbrq4so2rX982mLTv_33wEIMCwhQYE4RpsXUzJT4Y96xs85y4ofAIl2m3D4fdSBJRRTp2-xyKZbcw&n=1&u=aHR0cHM6Ly93d3cuYW1hem9uLmNvbS9kcC9CMDdONjRGTDNE
