KnNashua
I plan to buy a workcycle cargo long (a bakfiet/box bike, wooden box in front of handle for 4 kids.) For the one monster hill that guards the only way out of our neighborhood I plan to add electric assist, and have chosen the mid drive gear Bafang / 8fun BBS02 750W at 48v. I plan to wait until the new 25A BBS02 controllers are available in the next few weeks.
Any concerns about adding a mid drive to a box bike, particularly this cargo bike? Concerns on this particular drive? New to all this.
I'm checking with store that the bracket width is either 68mm (2.68 in.) or 73mm (2.87 in.) wide bottom bracket shell and 35mm inside diameter.
Another concern is with the step through frame (not diamond) the motor goes under, but with this non-offroader and the steering rod so low as well is that really an issue?
Was going to go with with falco hub drive but this bike has drum brakes, no fork mounts for calipers, a nexus 8 shifter in back, an odd fork for 20" in front so can't swap, was going to put in front add magura hydralic rim brake and change out glossy painted rim for machined one. Using a mid drive avoids all that.
Want the power to climb, but plan to pedal and with kids in so won't be cruising high-high speed, so need large e-assist load, but little total amps used over entire ride, so don't need a lot of amp hours on battery. That being said other than preferring space wise a downtube battery, don't know what requirements in battery choice should dictate battery selection other than COST.
Thanks for any input. Anyone done something similar?
