Hello all,
Done my research and feel the BBSHD is my best option for me....lots of hills, don't care about speed, not commuting.
Kit will be going on a Orbea MX 10 29er
Gear Sensor: Not needed?
Have read several posts about this, I am gentle on my drive train and understand it can easily be added later
Brake Sensor: I have hydraulic brakes, the generic sensor offered by em3ev will work for me? Not needed? Would rather not buy complete setup as I already have a decent set up.
Battery: Any builders in the US that I should be looking at besides Luna?
Install: Is the California ebike install tool worth buying if this will be my only e-bike? In other words is it a convenience item or is it necessary for a proper install? Also my BB is 68mm english thread.....reasonable BB tool suggestion or is Park the way to go?
Kit as picked out currently:
Bafang 48V 1000W BBSHD Ebike Kit (~1500W max) Mid Drive Kit With Battery Pack Option
Display Type:
Eggrider - OLED Smart Display
Throttle Type - Left Thumb Throttle (type 2)
Ebrake Type - 1pc Generic Sensor (Hydraulic Brakes)
BBSHD BB Size (Check Carefully) - 68/73mm (Standard)
Current Rating (HD-48V) - 30A (1000W)
BBSHD Chainwheel - BBSHD 36T Bling Ring (Black)
52V (14S6P) Hard-Case Triangle Pack with Smart BMS and Bag option - 52V 18.6Ah (14S6P-33G) High-Energy Hardcase Pack, 40A Smart BMS
58.8V Charger (for 14S, 50/52V Battery) - 58.8V 5A Charger (with 90/100% Switch)
AC Plug for Charger - USA
Any bits or bobs I am missing for a proper install?
Thanks in advance
Display Type:
Thanks in advance
