Stu Summer
I have three BBSHD's over 5 years and have replaced three controllers (stock) but the problem I am having now with my heavy and lead footed son is melting the Anderson connectors between the controller and the motor (with accompanying ruining the wiring insulation. One way or the other I get shorts to the housing or broken connections. We have normal Dolphin 30A 52v batteries. 1. Would different connectors work better? What do you suggest? It has to be short to fit in the tight space. Did the Ludicrous controllers use a different higher power connector?
Also, recommendations on an external controller for when these go burn out? I don't need more than 30A, I just need durability. It is interesting that the nylon primary gear has never melted. I'm wondering why other's gears melt but my connectors melt.
