kiltedcelt
The way that most tandem drivetrains are laid out, whether it actually has a shifter at the middle/stoker position or is a chain that runs directly to a geared hub - if you stick a BBSHD on the front of the bike (captain's position), then does the chainring tooth count on the motor even matter when figuring out gear inches? If the BBSHD is just running to the chainring setup in the middle of the bike, and from there back to a cassette with derailleur, is the only chainring that matters in determining highest/lowest gear and top speed the one in the middle at the stoker position? Logically it would seem so, but I'm wondering since most of the time you see Bafang mid-drives running directly to a rear wheel, does introducing this intermediate crankset/chainrings like on a tandem mess up anything related to power transmission? I guess the alternative is simply to make sure that whatever gearing you want is based on what is installed on the motor and simply duplicate the tooth count on the chainrings on the stoker crankset.
