For use with phaserunner and bafang mid motors
to prevent the motor from overheating, I want the phaserunner CA to step in and limit the power.
the main thing is what temperature is maximum that is sustainable for the engine? I read at Bafang 80C° and sometimes 120C°.
where to best place the 10K NTC thermistor for CA intervention?
Is it better to use KTY83-110 thermistor? What is the benefit? To use an actively driven signal?
I use the Bafang BBS02, BBSHD and the M620MM G510.750/1000.C motors.
In the bafang BBSHD and the M620 are thermistor in the motor but there are two versions of thermistor used.
how to know witch is used, to set the correct info in the CA, or better use mine own?
