Canis Lupus
- Joined
- Sep 30, 2009
- Messages
- 281
I have some questions about battery cycles, but first some background.
For better or worse, I have decided to purchase a BionX system although this isn't set in concrete yet. The main factors setting me on this course are:
1. the weight of the system
2. it's compact looks and tidy appearance
3. quality control
4. superior power management system, informing the rider of battery level better than most rival systems, allowing for greater ability to ration its usage during a long trip, such as when touring.
5. regeneration
It's the last point I wish to ask about to those who may have some technical expertise and/or experience with this system.
Firstly, if the battery is being constantly exposed to regeneration, how does this impact upon the expected number of cycles (lifespan) of the battery. It is said to be 500 before the voltage begins to drop. It's never been clear to me how this idea works in practice. The type of battery I will have will be the same as in a laptop. I hear different things regarding how to make best use of the battery to prolong its life on a laptop. One of which is that the battery should be discharged at least once a month. Another person I knew told me she achieved the best life out of her mobile phone by only charging it after it went flat. My question is this, if the battery is exposed to regeneration going down a big hill, or even as a result of the brakes being applied temporarily, does this count for 1 cycle. How does the battery know, one way or another, the recharge it just received is not a cycle. Sorry if that sounds dumb, but I can't think of a more technical way of putting it.
Secondly, has anyone conducted a thorough test on the regenerative abilities of the BionX system. Is it a gimmick or does it prove a valuable asset on longer trips. Presently, I am Greece. Last summer I did a tour of Greece on a Trice T. It was hard work in July and August when the real heat of Greece made the mountain climbs seem like they had gone up a few degrees also. Eventually, it wore me down a bit and I vowed to get an elect assist to help with the climbs which were proving so difficult. On the flip side, coming down those mountains was a lot of excitement, but a lot of energy was being wasted as my brakes were being given a good work out and heating up. The BionX system with its ability to have varying degrees of regeneration seemed ideally suited to take advantage of this situation while touring. But how much energy would I actually being putting back into the battery and (see 1) would I be shortening the life span of what is quite an expensive battery as a result of using it?
When and if I buy and install a BionX system, one of the first things I intend doing is climbing the nearest long and steep mountain and flatten the battery in doing so. There is no shortage of climbs around here capable of doing that. Then I will descend the mountain while the controller is set to regeneration. Then I will climb the hill again and then see how far up the battery takes me unassisted. All this will be done without adding the variable of pedalling. I intend to buy the 350 system which has the throttle, allowing this. I will do it three or four times, depending upon whether setting 4 provides too much resistance to make the test practical. Each time I will up the regeneration setting from 1 to 4.
Has anyone else done such a test or have information which might prove useful? I am surprised BionX does not provide any practical information on the feature. Maybe that is because the feature doesn't really give much which is worthwhile in terms of energy.
3. quality control
5. regeneration
