I testing my logic on how I charge my battery pack and whether the BMS can protect it while charging, with some assumptions about how the BMS behaves (which may or may not be accurate).
I charge my 14S pack to 4.15V per cell, or 58.1V, and discharge to 52V, ~3.7V per cell. Here's the logic I'm testing:
I’m trying to see how much risk I have of damaging my pack, using my charging/discharging routine, assuming this type of BMS behavior if I don't balance my pack often. I don’t think it would ever get as far out of balance as described, and I’ve only balanced the pack twice and it didn’t need it either time.
- If the typical balancing BMS behavior is to stop charging when any cell group reaches 4.2V, then under my routine, no cell group would charge greater than 4.2V.
- If the typical balancing BMS behavior is to not balance until the pack reaches full charge, or 58.8V, then the pack will not balance under my routine.
- If the pack is not balancing, then the most out of balance the pack can be would be for 13 groups to charge to 4.2V, and one group charged to 3.5V when the pack is charged to 58.1V. If this is the case, then when discharged to 52V, it seems like the lowest group would be at close to 3V (although the discharge curve for the cell type would come into play).
